BFL13
Mar 13, 2014Explorer II
Brake Controller/Trailer Brakes UPDATE Question
(Update question 19 March)
I am trouble-shooting a problem and I am stuck on where to test next. All help welcome!
Have Tekonsha controller and Dexter trailer brakes 2003 era.
Lately, the manual slider on the controller does nothing for braking with no truck braking, although the light goes from green to orange as it slides across as usual. It used to make the trailer brakes come on and you could do the rest of the setting up for the controller.
Towing seems ok where the truck-trailer seems to stop as usual, even down-hill, but I cannot tell if it is all truck or not.
With the truck and trailer parked, 7-pin connected, all the Tekonsha setting up procedures seem to happen ok. got the orange light vs red just right, same as usual.
While parked, 7-pin connected, truck brakes on with bricks on pedal, the trailer brake lights are on ok. (The other 7-pin lights etc all work too)
While like that with the truck pedal down some with bricks, I scraped some of the blue trailer cord wire under the kingpin to see some copper and got 8 volts between that and kingpin ground.
(I think I read that you should get increasing voltage there as the truck brake pedal goes down, but have not tested that)
To see if the trailer brakes work at all, I disconnected the 7-pin and yanked the breakaway pin out. Got 12 amps showing on the Trimetric, correct amps for these brakes according to Dexter manual, and also the truck pulling a little proved the trailer brakes are locked. Then when breakaway pin replaced, truck pulled trailer easy, amps nil. So the brakes can work.
How can I find out while parked if the brake controller is doing anything to brake the trailer instead of it maybe being all truck?
Is it possible the controller can work but the slider bar doesn't do anything even though the lamp goes from green to orange as the slider goes across?
Thanks.
Thanks.
