mbopp
Apr 05, 2020Explorer
One axle's brakes weren't working on our trailer. The wires are spliced using large weatherproof insulation displacement crimp connectors. Probing through the wire insulation with a "T" pin showed I had a bad connector. I cut the wires, stripped, spliced, soldered, and used shrink tubing on the splice. Problem solved.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
