pbitschura's avatar
pbitschura
Burner tube assy. older Norcold Frig
Next project; disassemble and clean the burner tube on my Norcold Frig. It looks like two nuts and it should slide out.Is there some adjustment required to align the igniter and tube beyond comon sense? Recent events lead me to believe a cleaning is in order. It's a 1988 C.What say you about cleaning the flue? Any pointers would be useful.
  • Why not do a REAL burner area tune-up. A lot better than just using compressed air.
    Most refrigerator owners manuals on older models covered what needs to be done. Suspect many newer ones just suggest taking it to a dealer. But you should be able to find instructions, or ask and we can post them.
    If you read back, you will notice disassembly will destroy parts which now must be fabricated, and, in the end, it will be a dealer repair and upgrade on an '88 frig.
  • Sorry, Didn't get back here till late today.
    I had to make a new gas pipe from copper tubing. About $8 in tubing and fittings at Aubuchon hardware.
    This looks doable. I assume flared ends and friction couplings?
  • This looks doable. I assume flared ends and friction couplings?
    Yeah. I had to buy a new flaring tool. I destroyed my last one making rigging for my Daysailor.
  • Gjac's avatar
    Gjac
    Explorer III
    When I replaced my old rusted out burner with the new style flare fitting I used the existing Al gas line and just flared the end. You can see from the above picture the "S" tube has plenty of length to it. I used a tube cutter and flare die both of which I had already. Chris Bryant's advise was very helpful on this project.
    In my case, the length isn't there to use existing aluminum tube. So it will be copper.
