wa8yxm
Jul 19, 2023Explorer III
What happened? You loaded all your "Travel stuff" and thus loaded it down.. likely about 1.5"
This is easier with a car... Measure the bumper height with the car basically empty. Do this at the rear bumper.. Now open the trunk and set 3 or 4 5 gallon pails of water inside (however many you can fit) and measure the bumper height again.. Now remove the buckets .. carefully (you might put only 4 gallons in)
Each gallon is what about 8.6 pounds so 4 times 4 gallons is a bit over 250 pounds.. Now imagine all the stuff you put in the RV.
