tvfrfireman
Jul 19, 2023Explorer
SuperBus wrote:
You may have an intermittently failing leveling valve on that corner (for your air bags). If that is the case, obviously you'd want to get it replaced to resolve the issue. But, in the meantime, dumping air using your jack controller might correct the issue by moving the leveler through some of its stroke, thus getting it to allow air back into the air bag and raise that corner of the coach back up.
Thank you Super bus for your assessment. I am sorry I have not enough experience in these systems to understand what you think I should do. If there is something I could read that would help me to understand I would be grateful. I don’t understand what the jacks have to do with the leveler. Are these two different systems (the jacks and the self leveler)? All the jacks retract fully. It is that the front left jack was sitting fast on the wood block when the night before there was plenty of room between the block and the pad.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
