ShoelaceExpress's avatar
Mar 29, 2017
Can I charge/maintain 12V batteries in parallel?
We had an older pop-up, but never had a battery on it. We recently upgraded to a 31' Bullet Premiere 31bhpr. SOOOOO HAPPY RIGHT NOW! haha.. ok, onto my questions about charging/maintaining:
The new TT needed a new battery, so I ended up purchasing two deep-cycle RV/marine batteries to install in parallel. I haven't hooked up the batteries yet, but will shortly.
1. I have a 12v battery charger/maintainer at home. Is it possible to hook the two batteries up in parallel in my garage and charge/maintain the batteries like that? Or should I just go buy a second charger/maintainer?
2. For while camping, I bought 2x40W Coleman solar panels (80W total). I need to find a iMob 4-in-1 connector so I can add both 40W panels together before the 7A charge controller - does anyone know where I should look? I've found them for $7 online, but they want $25 shipping to Canada.
3. Since the batteries will be in parallel while connected to the trailer, is it ok for the solar panels / charge controller to be connected to the parallel batteries, or should I disconnect one at a time and charge them? Alternatively, I could disconnect them from parallel and use a panel and charge controller (since I have two of each) on each battery. Just wasn't sure what the proper charging technique is.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
