Terry78's avatar
Terry78
can I seperate the 12 volt from the 110 system?
Yeah. Fulltimer with a problem.
I am pretty sure my converter is shot. My question is can I
Seperate the 12 volt system from the 110 system?
I can use lamps for lighting. But would really like to use the wall
Outlets to plug stuff in. I use a heater buddy for heat.
I think the 110 side is ok but there's a problem with the 12 volt
side. The trailer is a 79 Terry 24 foot. No serious electronics
In this model. Can I? Huh? Pretty please?
I did put a new heavy duty battery on. But still get loud hum and
Clicking from the converter.
  • Old-Biscuit wrote:
    Turn the 120V AC Circuit Breaker for converter OFF or unplug it if not wired to a CB) and 12V DC system is strictly on battery supply...which will then need an alternative source of charging
    Or connect a standard car batter charger to the RV battery.
  • 120V AC and 12V DC systems ARE already separate.
    Replace Converter and then you have best of both worlds
    Working Charger for battery/DC System Power source when connected to 120V AC and
    Battery to supply DC System when NOT connected to 120V AC
    120V AC System:
    A/C Unit, microwave, TV, Fridge/Water Heater electric elements, wall outlets, Converter
    12V DC System:
    A/C Unit T-stat---Furnace, water pump, Lights, Fridge/Water heater Propane controls, fans, etc
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
