rk911
Sep 05, 2016Explorer
dstone wrote:
We bought this 1995 Fleetwood jamboree a few weeks ago. Plugged it in at home and it worked fine, AC and everything. Then the breaker tripped repeatedly. Our neighbor, who is an electrician, put a new plug on the cable because it was fraying some. Worked at first only when we cut the breaker off in the house and in the motorhome before plugging it in then turned the breakers back on. Breaker in the house would still kick off periodically. Now the breaker will not stay on it all when we have the motorhome plugged in even though everything is turned off in the motorhome. What is going on? Any help would be appreciated.
are you plugging in to a std house outlet (115/120 vac) or a 30-amp RV outlet?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
