Sam_Spade
Sep 07, 2016Explorer
dstone wrote:
Could that have been an incorrect plug?
The breaker in our house does have the test button. Will check the outlet tomorrow.
YOu should trust that your electrician friend would NOT install an incorrect plug.
Your breaker IS a GFI type and as was mentioned before, many RVs don't get along good with GFI circuits.
You REALLY need help from a professional here. If not your neighbor, then hire another licensed electrician.
I still recommend starting with a new breaker. Relatively cheap and easy. (But given your level of expertise, you should NOT attempt to do that yourself.)
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
