downtheroad
Oct 23, 2018Explorer
You need the male end...it's going to be hard to match unless in the instructions that came with the gfi there is some info.
Maybe call the company that made the gfi and see of they can direct you..
As you said, easiest is to cut and strip and use easily available connectors like wire nuts or butt connectors...
I found this, .......terminal socket >>>LINK
Good luck with it.
Good luck with it.
