- nicpaigeExplorerSquare D™ by Schneider Electric QOM1 frame-size 50 amp Double-Pole Main Breaker!
this statement is why I purchased this bolt in main breaker. - nicpaigeExplorerI am installing this in my car hauler / toy hauler conversion. If I can run it on 220/240 I believe it will be more efficient.
- People mod their RVs all the time with stuff not designed by the manufacturer.
Getting 240v is a slam dunk.
I would probably add a subpanel at the cord entrance and pull wire to the split unit. Probably get a quad breaker with 50/20 connection and you are good to go. Worst case you get two breakers.
Subpanel might have to go after the transfer switch if you have a generator that gives 240. - cavieExplorerYou can only access 240 volts in an RV that has been designed to do so. 90% of RV's are not designed to access 240 volts from the panel. If the main breaker is in the middle of the panel than no, you cannot access 240 volts. If your RV has a 240 volt washer and dryer then yous you can do it.The main breaker will have to be on one end.
- red31ExplorerYes, you'll need a 2 pole breaker sized for the air conditioner, of course you'll need a panel that can accept a 2 pole breaker and room to add it.
- Big_KatunaExplorer IIBuy a 120 volt version. They make them.
- Charlie_D_ExplorerIn your home or RV? Little that I know makes me think you are planning a permit spot if using in RV?
- YES!
- nicpaigeExplorerThis is the main breaker in my panel.
Square D™ QO™ 50 amp Field Installable Main Breaker
Model Number: QOM50VH
EVERYDAY LOW PRICE $47.99
11% MAIL-IN REBATE Good Through 8/31/19 $5.28 FINAL PRICE$42.71 each
You Save $5.28 After Mail-In Rebate
Qty:
* Mail-in Rebate is in the form of merchandise credit check, valid in-store only. Merchandise credit check is not valid towards purchases made on MENARDS.COM®. Learn More
Not sure what to buy?
Check out our Buying Guides!
VIEW NOW
FREE Ship To Store
FREE Ship To Store
Available for Special Order at
TIPP CITY More Information
Get it as soon as 09/09/2019
Delivery
Delivery
Available
View Shipping Options
View Return Policy
Protect a breaker panel in a load center with this Square D™ by Schneider Electric QOM1 frame-size 50 amp Double-Pole Main Breaker! You can use this main breaker for overload and short circuit protection of your electrical system; it's compatible with QO™ and Homeline™ load centers, CSED devices, and NQOD panel boards. It accepts aluminum or copper #12 - 2/0 AWG feeder wire. It is both UL listed and ANSI certified to ensure safety. The ANSI-certified and UL-listed unit is rated for 120/240 VAC and 22,000 AIR. QO™ circuit breakers have features no other manufacturer can offer; they come in many sizes and meet the needs of virtually every function in your home or business. These types of quality and industry-exclusive products keep the Square D™ brand ahead of the competition, and that's why they are builders' and electrical contractors' first choice in electrical protection.
Dimensions: 4.3" W x 4.2" H x 5.3" L
Brand Name: Square D
Square D
Features
Load center main breaker
UL listed and CSA certified
240 VAC
Bolt on
50A
22kA
QOM1 frame size - 2oldmanExplorer IIThe pictorial of a 50a service will be along shortly.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
