opnspaces
Oct 25, 2019Navigator III
Are you saying that you are plugged in to shore power (via generator) and you do not have 12 volt power?
Y9ou might have two different issues going on, a battery disconnect and a bad converter.
First thing I would check is all the connections on the battery. Make sure the nuts or wingnuts are tight on the cables. make sure any and all connections you can find are tight.
Trace the negative battery cable and tighten the grounding bolt or screw at the frame.
Then trace down the positive cable until you find either a circuit breaker or fuse. Check or replace the fuse. If a circuit breaker see if it has a reset button on the side. If not find a way to jumper the two threaded posts together which will bypass the circuit breaker.
With the shore power disconnected go inside the trailer and pull the front off the breaker panel so you can see the wiring. Make sure every screw you can find is tight.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
