brows827
Oct 27, 2019Explorer
rrupert wrote:ScottG wrote:
Not out of the woods yet. Need to know why it tripped and fix the real problem.
It could be nothing more than that breaker has become oversensitive. You may want to replace it with an automatic reset breaker.
Hi - everything worked fine over the weekend. Then I was towing it and the right brake engaged as I was driving - right side brake light was on but not the left. I unhooked it from the car trailer connection and it disengaged so I took it to a gas station. I then hooked it back up to the car, but no lights work so I checked the same breaker where the positive battery cable connects, and lo and behold, it tripped again.
You think it could be an oversensitive breaker? You think the automatic reset breaker is something that would solve it?
Thanks in advance for following up on these.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
