- Cummins12V98Explorer IIIGlad you are good to go. For future reference do you know how to level your RV with the controls manually? If not it would be a good idea to know the procedure.
I never use AUTO mode to level, I use the Manual mode. Simply don't like the front of the RV dropping down so low with 6k pin weight. - mailman-retExplorerWhile I was on the phone with Duchman, they directed me to what turned out to be the Lippert Control Module. I am making note of your experience and now know where to check should I encounter a Lippert malfunction. Thank you for this information. I noticed that I had difficulty getting the cover off as when I bought the RV, I had fabricated and installed a sliding tray for full pass through access by making a sliding tray that would bring everything to me just by sliding the tray half way out on either side. I also made a trough for that shelf to slide in, with a bracket to prevent me sliding it to fer out, unless I needed it all of the way out. This trough wall is made with a 1X4 and stands too high to easily pull the Lippert Panel cover. I shall remove just enough of the trough wall to allow easy access of the panel cover. I installed a door latch bolt to lock the tray in position on the passenger side so that it couldn't move while traveling. I will soon try to post photos of this system to show how it works. That is if I con remember how to post photos.
- fowlthingExplorerFound the problem. And it took a voltage meter. The fuse in the front storage bin on the wire from the battery to the control module was only allowing 11 volts of juice. The fuse was lit up and showed continuity.
Also Lippert says the wire from the control panel should be connected directly to the battery not to the block near the battery.
I did that and put a new fuse in and it all works. 2 volts low and it would not work. Hope this helps someone else in the future. - fowlthingExplorerI have ordered the control module that is in the front storage compartment.. maybe it will do the trick
FYI figured out that after opening the valve for the front legs... we could hit a slide out button and the front legs would raise and level.. little easier than the impact wrench in side the storage compartment. - fowlthingExplorerReplaced the Lippert panel. More lights come on. But. The LCD does not.
Any suggestions are welcome. - fowlthingExplorerManual override of the hydraulic jacks wasn’t very difficult. Used impact wrench and Allen wrench.
Going to buy a new control panel and see if that solves the issue. - fj12ryderExplorer IIIUnless it's really complicated perhaps you could share how you resolved your issue. Especially if it's the same leveling system.
- mailman-retExplorerI called the phone number on the brochure to get hold of a person and it took less than half an hour to get the resolution to my mess up. I didn't want to catch someone at their computer.
- fowlthingExplorerThanks. I am too tired to do anything else tonight. I sent a chat message to Lippert earlier. But no response. Yet.
- mailman-retExplorerHave you made an attempt to contact the manufacturer to see if they could guide you to a resolution? August 17th found us nearly halfway to our destination in Pennsylvania,and I couldn't locate my heart meds in the TT. Mistakenly attempted opening one of the slides to get into the closet without grounding and leveling it. Our "In Command" retaliated and erased that slide. I contacted Dutchman, the manufacturer, and they walked me through a couple of steps to correct it. Nothing worked. The gave me the phone number to A.S.A, the engineers in control of "In Command" and in three short instructions, I had full control again. Two weeks have gone by now, and no bills from either. You have the same leveling system as our DENALI has.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
