TOL's avatar
TOL
carburetor float failure
I was having problems starting my 2 year old Onan 7000 Genorator Model 7HGJAB-900k this is well maintained by me. On my last 5000 mile trip I had notice that it had become hard to start at times or would stop while I was driving and hard to start at times, I was driving at high altitudes and hot weather, thought it might be getting a little warm checked it and made sure altitude adjustments on carburetor were at 5000 ft checked oil was able to start it after a little while this continued a few times during the trip. I am now at my snowbird destination and my generator won't start at all, so I went to looking deeper into the problem and found that the fuel float was full of fuel and allowed fuel to continue to flow freely into the caburater out the air cleaner and down along side the generator in my opinion THIS IS A SAFETY ISSUE !! raw fuel being poured out on a hot generator engine. That being said, if your having problems with flooding this should be something that needs to be checked. I have dealt with Onan before and as everyone I'm sure knows trying to talk to them can be like pulling teeth. This is not an uncommon problem and there are numerous posts on this issue and how to fix it with a 2 to 300 dollar new carburator. My quest here is to inform everyone of raw fuel on a hot eng when trying to start it, I will not be taking this to Onan, but to the agency's that can put a recall on this dilemma.
  • Carburetor floats can be fixed, repaired or bought. You don't need to buy a carburetor to fix the problem. If it quits the fuel pump will stop. If it doesn't start in a few seconds stop at see why. Not much fuel is lost when it isn't running.
  • I have had to replace floats in tractors/lawn mowers/chippers over the past 30+ years. Since all the floats are pretty much the same I am not surprised you occasionally get a bad one with Onan. If I had two year old Onan generator with bad float I would suggest talking to Onan rather than the govt.
  • I am a retired small engine tech and have seen this many times over the years. There is little anyone can do to prevent the problem short of buying a diesel which is fuel injected although the plastic floats are an improvement over brass.
