hypoxia's avatar
hypoxia
Carefree One Touch Door Awning
I can't figure out how to take the cover off of the discontinued Carefree One Touch Door Awning. The motor won't move even when jumpered and I can't see a manual drive like the patio and window awning has. Does anyone have or know where I can get the service manual? Carefree of Colorado discontinued awning manuals do not include the door awning.
  • forumcoach wrote:
    Three screws on the backside.
    When the awning is stuck all of the way in it can be difficult. When stuck in the out position it is easiest to remove the awning for access.
    I use a screwdriver with a 90 degree bend to remove two of them. The third one I use a phillips drill bit that I have shortened and then turn it with a wrench. That screw does not allow much space between the cover and the motorhome.
    Once you remove those screws the cover will come off.
    Thanks, I'll take a look at it this morning.
  • Three screws on the backside.
  • Did you check on line? Many manufacturers keep a library of manuals on line.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
