Acampingwewillg's avatar
Acampingwewillg
Explorer II
May 21, 2017
Changing a Kwikee one step to two step
I think my auto one step has finally had it, I've replaced the motor a couple of times over the year's and all has been well until the latest. Anyways, I have a Series 28 one step and I'd like to change it to a two step. As far as I've been able to tell, there is no direct replacement. The Series 32 two step is about 1/2 wider and I think I have enough clearance to allow this change. Just wondering if anyone else has made the change from one to two steps and what other things I might run into making this change?
Thanks for any info....
  • I don't know how much I can help you but you do need to know that Kwikee is no more. There have been at least two owners since they retired. I am not sure how much difference there is in the dimensions but I think the size is still the same.
    IIRC they have stopped using the window lift motors of old and the new steps come with exposed gearing. The new owners as I remember are Lippert Components. There is a fact sheet that gives the dimensions and should be available on line. The mounting bolt pattern is different and the rise is about 4 inches more with the Series 32. The extension is about 9 inches more.
    I'd measure the rise for both stored and extended to make sure you will have clearance. In the stored position the step from front to back is almost 2 inches greater.
    I kind of like to see stuff so I cut out profiles and hold them up to judge the fit. Pretty easy to do and is a little more descriptive than a tape measure.
    Good luck and have fun.
  • j-d's avatar
    j-d
    Explorer II
    Our coach is a 2003 model year, probably built in 2002. I mention that because if your step is OEM, it's probably covered by Manual 875, and a new step by Manual 888. Best I could tell from trying to work on an "875" step with an 888 manual, it was the control box and gearing arrangement that changed. But I don't know about the rest of the step. That big steel part...
    You of course need to find out if two-step doesn't extend too far, and hit the site pad before it's fully extended. I can tell you how far our 40 Series two-step drops but I don't know what the series differences are.
    The other thing for me, would be "Does the 32 step's mounting bolt pattern match my 28's pattern?"
    I don't know if this "Identification Guide" will help you, but I notice that the "28" and the "32" step assembly part numbers both begin with the same group of digits, then "28" or "32"
    ID Guide
  • I would GUESS...as long has you have no "height" problems, and the space to mount it (widthwise) why not? Got the clearance? Go for it....and g'luck!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
