Thanks for all of the comments. This really wasn't intended as a debate about the
type of anode material to use. I just want to remind people to check their hot water tank anodes as part of their annual maintenance…. That is,
if their tank has one.
jplante4 wrote:
Almost every pic I see, the nut has Teflon tape. Isn't that also an insulator?
There is good conductivity between the brass plug and the water tank and between the anode & the plug as well.
valhalla360 wrote:
... no reason to go magneisum. It just needs to be lower on the scale and it will do it's job.
There are lots of reasons to use Magnesium instead of aluminum!
-First and foremost is the health issue; The jury is still out on some of the concerns (e.g. alum' as a factor in Alzheimer's disease), but, just the same, there is NO known function for aluminum in human biology. At high doses aluminum is known to be toxic. On the other hand, Magnesium is a beneficial and necessary mineral. I will add that I do not typically drink water from the hot tank, but it is an unavoidable fact that some will be mixed with the cold water in the plumbing fixtures.
-Aluminum expands as it corrodes which can make a (tight fitting) anode difficult to remove from the port.
-Aluminum has a tendency to flake off in chunks as it corrodes and the resulting debris can be difficult to clean out of the heater tank. It can also enter the water lines and clog faucet aerators.
-Because it is higher on the anodic scale Magnesium produces a higher driving voltage which does provide more protection for the tank, especially in soft water.
More importantly, if it is completely gone by the end of the season, you are getting no protection towards the end of the season.
I'm diligent about preventive maintenance and check my anode regularly. There was plenty of magnesium left (still in intimate contact with the drain plug) at the time I chose to replace it. However I do agree that when the anode is gone, so is the protection.
Dutch_12078 wrote:
The Atwood heaters do not need or use an anode.
I do not currently (and have never in the past) owned an Atwood water heater. But if I ever did have a water heater with an aluminum tank I would choose to use a magnesium anode… It's dirt-cheap insurance against tank failure.
Old-Biscuit wrote:
That is a dual heat element with rod assembly......yours?? Wiring looks like maybe 12V DC & a 110V AC elements.
Yes, that is a 120Vac (500W) and 12Vdc (150W) hot water heater. I built it myself and I use the 12V heater as a "diversion load". It is powered by my solar charge controller. It works GREAT!… But I digress, as that is not the topic of this post ;)
Mag will dissolve quicker but can also react with microbes in water source and stink.
Yes that's true and I am aware of this possibility, but so far it has not occurred.
Cheers
-Mark
