DryCamper11's avatar
DryCamper11
Chevy P30 Chassis 1973 brake rotor clearance.
I had to replace the front rotor on my '73 P30 Sportscoach RV. The local NAPA had no listing for '73 dual rear wheel P30, but they did have one for the '75 and the rotor matched all dimensions, except thickness of the disk. When installed, The heads of three bolts holding the rotor shield on would slightly touch the surface of the rotor. I removed the lock washers and they still slightly touched. I had to grind the heads down 30% thinner to clear.
Does anyone know if I've gotten the wrong rotor?
TIA
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 21, 2025
