fj12ryder
May 01, 2020Explorer III
MEXICOWANDERER wrote:Well, I don't mean to bust your chops too much, but probably should have been using a breaker bar and not a ratchet. Ratchets are okay to loosen snug, or slightly tight, but breaker bar should be used for TIGHT. I've seen a few ratchet wrenches fail when they are used instead of a breaker bar, or had a cheater put over the handle.
I was using a short Allen with no success on the mandrel set screw. So I tried changing to a high quality German Allen metric hex socket. When the tension broke the Milwaukee hole saw jumped.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
