Padlin's avatar
Padlin
Choosing and installing an inverter
Background:
New 21' Fiberglass FW, all power related equip under the rear dinette seat.
2-6V Interstate GC batteries 232A
160w 12v flat mount solar, will add another 100-160w this spring/summer
Wfco 8955 converter/charger
Bogarts Trimetric 2030 battery monitor and SC-2030 Solar Charger Controller
No on board genny, have a Honda 2k
I do my own mods.
Looking to add a decent inverter to power an electric blanket or heat pad, and charge the laptop and camera. I currently use a cheap, noisy, 400w portable for the laptop and camera.
From reading this forum, I see my WFCO 8955 is not the greatest thing for my 2 6V interstate batteries, started looking into replacing it.
The existing circuit to the bedroom receptacles for the heating pad is the same one used for the microwave. That being the case I'll add the MW to what should be powered from the inverter. I checked it with a Killawatt and I get 1100w draw (700w unit) so I'll go for a 1500-2k inverter.
I like the Iota DLS-55 for a charger and the Xantrex Prowatt SW 2k inverter.
Xantrex
DLS-55
Looked at the combo units but for PSW they are out of my budget at $1k plus, hence my first question.
1. How can I tell if I need a PSW or MSW? If I went MSW I could get an all in one unit.
Hooking up an inverter:
The Xantrex has an optional remote, which I would get, and an Inline Transfer Relay.
I was thinking of using the output of the breaker to feed Input #2 and hooking the existing Romex to the output of the relay but this leaves no breaker for the output when running off the inverter.
2: Am I looking at this right or is there a better way? I'm open to all affordable suggestions.
There's more but I'll stop here for now.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
