DarkSkySeeker's avatar
May 16, 2017
Click, click, click
From the first time I turned on my TT furnace, I heard click click click from the AC unit. When I called my salesman from CW, all he said was, "at least if it doesn't get worse, then it is probably OK". However, we were out this past weekend and it is pretty annoying. So I googled, "click click dometic AC thermostat" and there are several accounts of this.
I am surprised how easy it was to "fix", and more surprised that this kind of thing is not in a set of FAQs for new RV buyers.
The dometic thermostat has settings that can stop the click click. Press and hold "-" and then press and hold "the select button". Then you will likely see "d1". Press the down arrow to select "d2". This sets the temperature differential that the AC looks for when trying to turn on.
Simple.
Works.
What bothers me is how simple the fix is and how this problem is not automatically addressed during the sales process.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
