time2roll
Jan 14, 2015Nomad
Plasti-mend can easily make a permanent repair to close the opening.
Basically you glue on a sheet of ABS over the hole.
OK I assume the tank is black ABS.
If you have polyethylene (usually white) then you need to have it plastic welded or a screw on plate cover.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
