wwest
Jun 20, 2014Explorer
SC camper wrote:
We are having a freeze up problem with the ducted Coleman mach 3 ac unit. The evaporator is clean and the filter is new.
We run it on high cold and turn the thermostat down from max cold.
Do you mean..."turn the thermostat down FOR max cold"..??
Sentence doesn't make sense otherwise.
This past weekend was in the mid 80s and humid but still had a freeze up over night, low 70s. My question is about the copper temp sensor wire.
not copper wire, gas filled capillary tube.
It is in front of the evaporator but not touching it. Should it be touching? I dont hear the compressor cycling. Should I turn the thermostat warmer to make it cycle? It blows good cold air until it freezes up. What else can I look at before taking it to the shop?
At 70F OAT the refrigerant condensing capacity will be beyond the design specifications for the A/C. So yes, raise the target cooling temperature and run the blower at MAX.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
