wwest
Jun 21, 2014Explorer
Bob Landry wrote:
Disabling the condenser fan if it were possible, would do nothing but cause the unit to kick off on high head pressure. Not knowing what refrigerant your company's split systems used, I can't comment on the effect of turning off the condenser fan, and that may have worked on those but this thread is about RV rooftop units. The condenser is where the heat transfer takes place so why would you want it to run hot enough to shut the AC down. There are no RV rooftop units that have a separate motor for the evaporator and condenser.
Has anyone else used a RV rooftop A/C for cooling the interior when the OAT is that low? Doesn't that low OAT have the effect of dramatically increasing the condenser section's ability to condense the refrigerant gas to liquid form?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
