duckman2018
Aug 04, 2019Explorer
dougrainer wrote:
I repeat, HOW do you know it is pulling the correct amps? You should hear a click when you turn the Tstat knob, so yes, zero in on the tstat. You can jump the 2 wires at the tstat to verify the Tstat is the problem. Doug
Doug thank for the advice. I don’t know if the thermostat wires are pulling the correct Amps just the fan motor and compressor. This thermostat is built into the housing not on the wall. When I turn the knob I don’t here anything but feel a click when turned to almost all the wall warm or red. Which wires can I just out on the manual thermostat inside the a/c?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
