dougrainer
Aug 05, 2019Nomad
duckman2018 wrote:dougrainer wrote:
I repeat, HOW do you know it is pulling the correct amps? You should hear a click when you turn the Tstat knob, so yes, zero in on the tstat. You can jump the 2 wires at the tstat to verify the Tstat is the problem. Doug
Doug thank for the advice. I don’t know if the thermostat wires are pulling the correct Amps just the fan motor and compressor. This thermostat is built into the housing not on the wall. When I turn the knob I don’t here anything but feel a click when turned to almost all the wall warm or red. Which wires can I just out on the manual thermostat inside the a/c?
I am going to repeat, HOW do you know about the AMPS???????? There is NO way a Novice can state such a thing. You have to have a specialize amp draw meter to tell you amp draw. Amps will not be a factor in your problem. Just trying to get into your mind set about Amps. There should be a Yellow and a White wire on the tstat. You connect them together. MAKE SURE THE UNIT HAS NO 120 WHEN MESSING WITH THE WIRES. Doug
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
