otrfun
Aug 14, 2021Explorer II
jodeb720 wrote:
outstanding!
Thanks all for the insight.
I'll start with trolling through the specs from the document library.
From there i'll start making decisions.
We're not going out in the 5er at least until October - so I have time to figure this all out. We're finishing the RV Makeover - and i'm planning the next phase of the update.
Take Care all and thanks for the suggestions!
josh
ktmrfs wrote:Check out the 48208C966, one of Coleman Mach's most efficient 13.5k BTU ac units. More than likely you'll have to special order the 48208C966. They're rarely stocked by RV distributors. Dometic can't come close to this unit in terms of efficiency (BTU vs. LRA/continuous current). It has a 50.5a LRA rating and a continuous current draw of ~11a under "desert" conditions---both excellent specs. Most 13.5's (especially Dometic) have a much higher LRA (60-68a) and a higher continuous current draw of 13-15a.
coleman has a 13.5K version that draws less current and has better (lower) starting current and LRA spec's. That's what I would go for.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
