myredracer
Oct 04, 2016Explorer II
danrclem wrote:
Myredracer, are those clamps you put on your quick connect supply available at hardware store. They look very sturdy.
The insulated pipe clamps are from a plumbing wholesaler. They are sized based on the o.d. of the pipe they're clamping - 1/2" IP or 3/4" copper, 3/4" IP or 1" copper, etc. Might be best to take in the part you'll clamping.
The flat stand-off brackets are for Uni-strut (or similar) electrical channel and HD carries them. Both the clamp and bracket use 3/8" threaded rod. I bought a couple of galvanized carriage bolts and cut the heads off.
The dust plug was the hardest part to find and I got it from an industrial hose supplier.
