garyemunson
Mar 07, 2019Explorer II
Command Electronics Taillight gasket leak
I'd posted this some time back. Since I find I need to do it again, thought I'd repost. The poor design of this light requires you to regularly replace the main gasket on a regular basis. The lens of the light only seals at the very perimeter of the lens. As the gasket shrinks from heat/age/UV rays, once it passes the outside edge of the lens, it begins to allow water into the interior of your RV's wall! The gasket barely protrudes a 1/8th inch when new so it does not take much shrinkage to put the back wall of your RV in peril. Many coaches from different manufacturers use this taillight assembly and all share this problem. Left alone, it allows water to leak inside the rear wall at both rear corners with the potential of rotting both the wall panel and the floor at the point where they attach to each other. If you have this type light, be sure to keep an eye on the gasket and replace it when it shrinks to the point it cannot seal out water anymore. A couple years is all you can expect out of this cheap gasket. Commandelectronics.com sells the replacement gaskets.
https://static1.squarespace.com/static/55144804e4b021a56f31ce24/t/599f0b2a9f7456fccccafbfe/1503595323561/003-30ProductInfo.pdf
