BruceMc
Mar 08, 2019Explorer III
These command taillight assemblies are very poorly designed. They don't lend well to crappy assembly either. Here's what I found after my taillights started filling with water not long after we purchased it new in October '15:
After initially removing the taillight, it was apparent the assembler forgot to install the gasket before wiring the fixture. They tore it in spots, then kinda tossed it in the hole:
The fixture, when it wasn't wet, was filling with dust:
In spots, the gasket wasn't even in place:
Additionally, the center clear lens gasket was the same material. One was designed with 2 screws, the other had 4.
To rectify this issue, I cleaned all surfaces, then laid a thin bead of clear sealant at the mating surfaces between the red & clear lenses, then assembled them. No more leaks there...
Next, I ran a bead of clear sealant around the perimeter of the red lens & set it in place, ensuring some squish-out around the perimeter of the lamp. I had re-drilled the holes as some were stripped, thus ensuring all 6 screws would seal the lens properly. I added a touch of sealant in the screw holes, then gently seated the screws. Once all was in place, I cleaned up the excess sealant.
I did not attempt to reuse the existing gasket. The new seal was created purely from sealant.
I've had zero leaks since then. No fogging, no water setting in the bottom, no dust, nothing.
If you are having similar issues, replacing the anemic gasket isn't going to help much unless you give it a little help. Don't just put sealant around the edge - if anything, back out the screws, pull the fixture away from the surface a bit, then force sealant in the gap. Pull the screws one at a time, put a dab of sealant in the screw hole, then reinstall the screw. Tighten gently & remove the excess. Next, remove the center clear lens & do the same thing.
Again, these are cheap fixtures, but they can be made watertight.
Good luck, and let us know what you did and how well it worked.
