Grit_dog
Aug 22, 2023Trailblazer
I can’t think of a single tow vehicle/motor home that comes with a 6 round plug. Haven’t even seen or used one in almost 30 years. And I’m around multiple different trucks and trailers regularly day in day out for the same 30 years.
OP may have a 6 pin connector, idk. But it’s far from standard if he does.
Regardless, it doesn’t matter.
OP, so a “battery charge line kit” is a small DC-DC charger I presume?
I don’t follow what you’re saying about reusing the red wire or not. If you’re hooking into the 12V hot lead on your TV trailer plug, then that seems like the the same/right spot to hook up the new thingamgiggy.
And the ground can be hooked either to the toad or the trailer connector from the road to the tv but the toad and tv must be grounded together too sometimes via the actual ball mount. Sometimes via the wiring, or both.
Doesn’t matter if 6 or 7 pin setup.
Note there are 2 different wiring color conventions for 7 pin trailer hookups. But you got good advice above to verify regardless of color or wire position what the function of each wire/pin is.
