Robin_n_Marian's avatar
Dec 03, 2013
convert 220 v plug to 50amp rv plug
Hi, I don't know if this is the right place to post this, but if there are any electricians out there, I have a question for you. I am aware of the difference between the 220v dryer type plug, and the 50amp RV plugs, which are really 2x50 amp 110v (poor explanation I know) and that you cannot plug the rv cord into the 220v plug without doing severe damage.
Anyway, my question is this.
Is there a way to make a short "extension" type cord that could be plugged in to the 220 v plug in the garage (or whereever)on one end and then convert that plug (maybe with some kind of converter or?)on the other end to the correct 50 amp power source (plug) which we could use to plug in our rv cord? Instead of having to re-wire the existing plug to an RV plug, (since we would want to do this at the homes of several friends and relatives who have these plugins for their welders, etc).
I hope this explanation makes sense.
Thanks
  • In the US and some parts of Canada, the elctrical code changed dryers and range receptacles to four wire. Both dryers and range circuits after about 1988 has four wires.
    Look closely at the receptacle for number of openings. It should have four on later installations.
    It is not only look at but must be tested for proper wiring.
    You should not attempt to make an adapter. The receptacle must have a neutral and a ground
    Thanks
    If the outlet is a 4-prong 220V stove/dryer one, then you can plug right in as it has the split 220V (2 x 110V) that you need.
    If the outlets are the 3-prong welder type then there is no way to plug your RV in there as there is only 220V available.
    As a previous poster said, such an outlet does not have the neutral you need to correctly power your RV. No converter/adapter cord is going to solve that problem.
  • That's it, I'm going to start with this thread since it is barely sensible because of the use of "plug".
    The device that is used to connect a male cord plug to power is called a "receptacle", or sometimes, an "outlet". It is not a "plug". A "plug" describes a male connector, usually at the end of a cord.
    \Rant over
    Your best choice for connecting your 50 amp RV power cord to a host's house is to use a 50 amp--> 20 amp adaptor. You would then have a GFCI protected circuit and will not have the added liability of any miswiring or insufficient protection from an unknown circuit in the host's house.
  • Welder receptacles don't normally have the white neutral wire,
    Art.
    As Chris says, I type much slower.
  • A properly wired 4-wire 240 volt plug is what you need- the only reason you cannot use a dryer type is they don't have a neutral, and use 3 wires (and look too much like the 30 amp 120 volt RV plug).. If the 50 amp RV plug fits, it will be fine, as long as the outlet is properly wired.
Having RV issues? Connect with others who have been in your shoes.24,233 PostsLatest Activity: Apr 11, 2025
