MEXICOWANDERER's avatar
May 11, 2016
"Cornering Lights" Circuit?
Remember "cornering lights?"
Flip on the turn signal and an area light illuminates that side of the rig you intend to turn toward.
As I age and my eyes grow weaker, I would appreciate incorporating this feature. But instead of a bulb, 17-watt CREE waterproof lamps would be utilized.
Flashers work by sending a pulse downstream through the directional signal switch. So any signal found there would be pulsed.
¿A diode and charge cap feeding a relay coil both sides? This means one circuit left and one circuit for right.
Finding obscure campsites, hidden side roads, as well as checking for obstructions before turning. I like that.
My Tyco relays have an 88 ohm relay coil. One Hz flasher pulse (more or less)
I don't want to have to fumble for switches. I'm busy enough as is.
Appreciate hints, pointers and criticism, as long as criticism is polite and intelligent :)
Having RV issues? Connect with others who have been in your shoes.24,342 PostsLatest Activity: Dec 11, 2025
