myredracer's avatar
myredracer
Explorer II
Aug 17, 2017
Couple of battery voltage & charging question
Have had an AGM battery (one) for a year now, not that being AGM necessarily matters. Never dry camp. Also bought a Progressive Dynamics converter/charger upgrade for it. Recently installed an LED voltmeter display to keep tabs on the battery.
Voltage normally floats correctly at 13.7. If I shut the charger off, the battery stays at 13.7 volts for a bit then starts to drop slightly. I believe this is normal? Haven't left it overnight to see what it levels off at but assume it should level off at about 12.7?
The only time the battery normally gets discharged is from using the tongue jack, putting the stab. jacks down and running the slide out and when I do the charger is correctly putting out 14.4 volts to charge the battery. Does the battery get discharged much and roughly how long does it take to get back to full charge? Does it help to plug back into shore power before operating the jacks and slide so the battery won't get discharged quite as much or does that help at all?
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Oct 07, 2025
