24rules's avatar
24rules
cracked tub
I bought a used travel trailer this spring and the only issue that I have is that the tub has a crack in the bottom,which is not a huge deal because we never camp where there is no shower house but it seems like I need to put some more support underneath the crack. the previous owner tried to fix the bottom but it has way to much give for his repair. What is the best method of patching the crack then I will be able to support from under the tub when repair is made? camping is winding down so I thought it would be a good time to get this repaired
  • Easy fix. Gain access to below shower and use expanding foam to fill the area under shower/tub bottom.
    Trace out on paper the bottom of tub/shower.
    Send it to Napco www.napcoltd.com
    They will send you a piece cut to your paper mold and glue to glue it down.
    Did this to a park trailer this spring and it is fixed forever.
    Pogoil.
  • I wouldn't bother... A replacement RV tub can be had for between $35 and $100 from Ebay depending on the model you need. I wouldn't take it all apart just to put the same one back in.
    I had our tub out earlier this year chasing down a ground issue with the outside marker lights.
    It wasn't that big of a deal, but I discovered that when they put the screws into our tub to hold it in place, the tub was not fully seated on the bottom support. Every time we stepped in, it squeaked and creaked like mad and as it turns out, there was a crack in the corner up behind the surround that was slowly working its way down towards the lip of the tub. That corner of the tub was sitting 1/2" higher than it should have, so you can imagine how much it was flexing every time we used it.
    When I reinstalled it, I made sure the tub was sitting flat on the floor before I screwed it in place, and made sure I used some high quality marine-grade sealant on the existing crack. The tub doesn't flex at all when we use it any more (and therefore, doesn't creak and squeak either).
    So, all that being said, I'd just replace it. It's not a difficult job at all. On a shade-tree mechanic's scale of 1-10, I'd put around a 3.5. Remove the faucet, remove the surround, disconnect the drain pipe, remove the screws holding it in place (probably 3 or 4) and it pulls right out!
  • is this tub going to be made of acrylic or fiberglass I am not sure
  • Look in you local yellow pages for bath tub repair,fiberglass repair or acrylic repair.
    I just had a quarter size hole fixed in a tub/shower floor for $125.00 ,alot cheaper than replacing the tub.
    My Jayco has the tub raised for the plumbing underneath.
    It appears they put a sheet of 3/4" plywood under it,then a 2x4 leg down to the trailers sub floor.
  • Boy, good luck with that. It's a bear to do, let alone keep it sealed. Sorry, just feelin' for ya 'cause I've tried fixing one.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
