benb21601's avatar
benb21601
Cummins Onan Generator oil
After countless hours of searching, I could not find the the oil specs recommended for the rv generator. I finally broke down and went to my local Cummins center, and bought the factory Onamax 15w-40. I say broke down, but honestly at $5.50/quart, i cant think of a reason to use anything else. But for anyone else looking for the specs, here they are:
API Certifications - CJ-4, CI-4, CI-4 PLUS, CH-4, CG-4, OF-4, OF/SL
As I said, 15w-40 is what they said to use, which is part #326-5336 for a quart. A quick search of my standard go-to Mobil 1, showed it did not meet all the same specs.
FYI- hope this helps.
  • mlts22 wrote:
    Is it full synthetic? Because of the way splash lubrication works, I wouldn't use anything else, just because a small amount of oil has to do a lot of work.
    Doesnt say synthetic on it anywhere, but it does say premium blend whatever that means. In talking to the service/parts managers, they said a couple things different in the Onamax is anti foam and anti splash. Either way, this one wont void the warranty, I gotta believe they stick their name on what they want in the equipment.
  • Is it full synthetic? Because of the way splash lubrication works, I wouldn't use anything else, just because a small amount of oil has to do a lot of work.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 25, 2025
