OP here. Fired up the rig and turned on the A/C. Started cooling and then, of course, the compressor started cycling. I bypassed the T-stat (believe so anyhow) but the compressor continued to cycle. I looked in the sight glass and didn't see any bubbles when the compressor was on but it only stays on for 4 or 5 seconds so not completely sure. Anyhow, what does it mean if the compressor does not run continuously when the T-stat is bypassed. Here's a photo of what I did. You can see the T-stat spade connectors and my bypass wire. Thanks.
jor
