theoldwizard1
Feb 12, 2018Explorer II
Dashboard ammeters are notoriously inaccurate.
First, clean the battery terminals and the top of the battery. At a minimum, spray it down with a strong spray from a garden hose. Max sure the battery terminal on secure.
Get a digital multi-meter. The $6 Harbor Freight meters are not very good, but their $24 meter is not bad. Craftsman has a few to choose from in the $35-$50 range. No need to spend more than that.
The last reading is the one that would indicate over charging. But over charging could be caused by a high load.
- Check and record the battery voltage before starting.
It should be between 12.0 and 13.0 - Turn the key on, high beams on and heater blower on high for about 5 minutes.
Check and record the voltage. It should be above 11.0 - Start the engine. Check and record the voltage. At a high idle, it should be above 13.8 but below 15.0
- Go for a 10-15 minute drive with all accessories turned off. Check and record the voltage at idle. It should be between 13.2 and 13.8
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
