Busdriver's avatar
Busdriver
Explorer II
Jul 18, 2015
Dead bolt cylinder
As I was unlocking my dead bolt lock the cylinder pulled out with the key do I need a new complete lock set or can the cylinder be replaced. The lock is fith wheel . I still have the cylinder can it be put back in?
  • jfkmk wrote:
    Our lock cylinders, including the dead bolt, had to be replaced due to a safety recall. The mfg sent the cylinders and instructions. I forget the exact instructions, but you had to turn the lock a certain way and pull the cylinder out. Perhaps you did this by accident? I'd try putting the cylinder back in, turning the key, and see if it comes out again. As posted, the whole mechanism isn't really that pricy anyway.
    that is my guess also. borrow a master key to replace it properly.
    bumpy
  • Our lock cylinders, including the dead bolt, had to be replaced due to a safety recall. The mfg sent the cylinders and instructions. I forget the exact instructions, but you had to turn the lock a certain way and pull the cylinder out. Perhaps you did this by accident? I'd try putting the cylinder back in, turning the key, and see if it comes out again. As posted, the whole mechanism isn't really that pricy anyway.
  • MH or TT? MH door lock assemblies are around 70 dollars, I suspect one for a TT would be a bit less. Finding parts without taking it apart and looking, who knows?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
