brisath's avatar
brisath
Dead radio, levelling jacks, keypad lock
My 2015 Jayco Melbourne class C isn't getting any power to the radio, auto leveling jacks, and keypad lock but all other power seems to work and it drives fine. If it is fuse related please help with locating the right fuse. Same with locating isolator or solenoid that may be the cause. I recently was messing with and lubricating a stuck contact rod on the side bottom of the door, if that helps.
  • Fixed! The solenoid behind the house battery has 2 fuses on it, a 5 amp and 7.5 amp. The 7.5 blew so when I replaced it they all started working again. Thanks for all the info, I learned more about the system by hearing the advice.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
