theoldwizard1
Sep 14, 2020Explorer II
Keeping flood lead acid batteries FLOODED at all times is the most important thing you can do. If they are on a charger 24/7, I would recommend checking the liquid level every 1-2 months, especially when the temperature is above 90F.
Keeping the outside of the battery clean is #2.
For MAXIMUM battery life, I believe that lead acid batteries should NOT be on a charger 24/7 ! 4 - 6 hours per day on a "maintainer" is plenty. Use a cheap mechanical lamp timer for your battery maintainer.
