rvshrinker's avatar
rvshrinker
Explorer III
Sep 14, 2020
Deep cycle battery maintenance
Hello experts
My TT and interstate batteries are there years old. The trailer is plugged into my house when not in use. It gets five or so trips per year so is plugged into the house most of the time. It is now on a dedicated 30 amp circuit but was previously on a 15 amp.
We have mild weather, almost always between 35-90 degrees. A few days of subfreezing temps per year, a couple weeks over 90.
I have never added distilled water to the batteries or done any other maintenance. I open the batteries to check there is water in there before every trip... But that's it.
This website sounds like I should be doing a lot more. It also is quite a bit over my head:
Is the a simpler explanation/resource for the essential tasks and checks I should be doing?
  • I just had to add water for the first time in over a year, and I also keep my trailer plugged in full time at home.
    Since I'm strictly a recreational RVer at this point, and have a generator (and 150 watts of solar), I don't worry about the batteries too much. I have a TM-2020 meter that tells me their current state of charge.
    I exercise them once in a while, but no set schedule. I otherwise pay little attention to them. I've gotten over 8 years of service from each pair of 6 volt batteries with that routine.
  • Add distilled water until it just reaches the bottom of the fill tube. Do not fill to the top of the case/cap. This allows for a adequate reserve and for the battery to vent.
    You can buy a battery filler bottle that will fill them to the correct level.
  • I clean the post IF I see any grud, check water level spring july and oct. a year ,if you,ve never added water? you need too.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
