TURNKEY's avatar
TURNKEY
Deep cycle or starter battery charging issues
I recenty moved from a class B to a small fiver. My old van had one deep cycle battery and I installed an isolator. This set up was good for several nights of light usage before I had to run the van to charge the battery. My new trailer seems to use a LOT more power. Granted, it has an electronic start fridge, rather than a constant pilot light as well as the furnace and a propane monitor(the old van was a 1982)I still think I should get more than 3 nights of use off a battery charge. We used very little light, no water heater, no fantastic fan and only 2 or 3 cycles on the furnace per day.
We dry camp 90% of the time and I intend to purchase a generator for now and solar when we retire in a couple of years.
I beleive we will have to charge fairly often, maybe daily.....but I don't want to be one of THOSE GENERATOR A##()&Les! who need to run their generator for hours at a time disturbing everyone's peace and quiet. I'm looking for a max 1 hour charge time.
I have a smart battery charger that will charge at 2, or 10-20 amps as well as an onboard IOTA convertor that has a 750 watt input @120 v that will put out 45 A at 12v. My local dealer sez the convertor really will only charge at 5 amps or so. He also sez deep cycle batteries should be charged very slowly for best effect.
Is my best bet to install a starter battery rather than a deep cycle on the trailer and charge it heavily and quickly? I recognize the best set up is to go with solar but can't justify the cost yet.
Thanks all for your anticipated input.
Turnkey
