TURNKEY's avatar
TURNKEY
Deep cycle or starter battery charging issues
I recenty moved from a class B to a small fiver. My old van had one deep cycle battery and I installed an isolator. This set up was good for several nights of light usage before I had to run the van to charge the battery. My new trailer seems to use a LOT more power. Granted, it has an electronic start fridge, rather than a constant pilot light as well as the furnace and a propane monitor(the old van was a 1982)I still think I should get more than 3 nights of use off a battery charge. We used very little light, no water heater, no fantastic fan and only 2 or 3 cycles on the furnace per day.
We dry camp 90% of the time and I intend to purchase a generator for now and solar when we retire in a couple of years.
I beleive we will have to charge fairly often, maybe daily.....but I don't want to be one of THOSE GENERATOR A##()&Les! who need to run their generator for hours at a time disturbing everyone's peace and quiet. I'm looking for a max 1 hour charge time.
I have a smart battery charger that will charge at 2, or 10-20 amps as well as an onboard IOTA convertor that has a 750 watt input @120 v that will put out 45 A at 12v. My local dealer sez the convertor really will only charge at 5 amps or so. He also sez deep cycle batteries should be charged very slowly for best effect.
Is my best bet to install a starter battery rather than a deep cycle on the trailer and charge it heavily and quickly? I recognize the best set up is to go with solar but can't justify the cost yet.
Thanks all for your anticipated input.
Turnkey
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
