DiskDoctr
Apr 18, 2017Explorer
SoundGuy wrote:
OK, one more time - when comparing one deep cycle battery to another you want to be comparing them at the 20 Hr rate. That DC31DT you're referring to is 20 Hr rated @ 105 AH, two would offer 210 AH, so obviously a pair wired in parallel drawn down to 50% SOC would offer you ~ 105 usable AHs. As far as heavy inverter draw is concerned 12 volt jugs will inherently suffer less voltage drop under heavy load than a pair of similarly rated 6 volts in series simply because internal resistance will be lower.
Okay, I just asked that part...again. But you answered in between my posts. LOL.
Thanks! :)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
