DiskDoctr
Apr 19, 2017Explorer
SoundGuy wrote:
...while the OP has been agonizing over which batteries to purchase he hasn't said a word about what charger he's using to maintain those batteries, which is critical if he expects to maximize the life of any battery he may invest in, particularly if he opts for AGMs or Gels instead of flooded
Well, been trying to work that out. Here is where the choice is at the moment, and key points.
1. Flooded batteries. Different chemistry and such would require other charging and higher voltages, which could affect my unregulated LEDs.
2. I have the WF-8955AN 3 stage charger at 55amps (load and charger)
3. We will be out up to a week at a time without shore power, but will have generator use a few hours a day.
4. We have Xantrex 1800 PSW inverter on its way to run 120v lighting and laptop power supplies, and likely try running microwave a few mins each am during quiet hours.
5. Strongly considering Group 31 12v deep cycle batteries, expecting to have 2, possibly 3 in parallel.
6. We will plug in the camper for an extended period when we return from the week+ trip, then a day or two at a time while on the 2-4 week travel trip to different places this summer.
7. I DO have several large chargers that can be used when we return home. Some are multistage, some are not. Most are not easily portable, but I have a 3 stage dual battery charger in the boat that may come out...not all worked out yet.
8. As inverter is direct wired and we move the converter to its own breaker and add NC relay to prevent it from being powered on inverter, and we likely add 30amp transfer switch (the built in ATS on the inverter is only 15amp, probably have to just skip it) to jump between shore/generator power and inverter power.....leads to....
9. A starter solar system could show up by the end of season or before next season, with appropriate charging upgrade that will top off the batteries.
As the system "matures" we are striving to take steps that meet our needs and expected needs without too much waste or replacements necessary.
10. We are adding 12v sockets and USB ports to natively power and charge devices without the inverter
11. I will be moving the cell wireless repeater/booster to this new camper and strategically placing the Mobley that just arrived today to allow my daughter to take her advanced classes this summer while traveling.
12. We *may* provide for the ability to isolate one battery as emergency use for the newly installed electric tongue jack and both 12v slides.
13. I'll be building extra battery mounts for 3-4 batteries.
14. The inverter will be mounted inside the front storage area on the soon to be added pegboard to line the full width compartment, while I pull the LCD monitoring panel, wire in RJ45/RJ11 (not sure which it has) to remote the panel to as of yet undetermined location to monitor, but provide the ability to cover it to shade at night in the master bedroom.
15. Replace the ceiling vent fan in the bathroom with a Fantastic Fan, after washing and resealing the entire roof, slides, sides, etc.
16. Replace the awning
17. Devise rear storage container rack setup and try to fit in all our gear
18. Work out a bike rack, possibly with a front hitch on the Excursion
19. Wash and wax the camper ( :) )
20. Paint any faded plastic, replace all window weatherstripping while cleaning and dry lubing the contact points and sliding channels
21. Finish replacing the cooling unit on the fridge and reinstall it, while making new air chimney/draft above the fridge and allowing for a new storage area above it.
22. Add LED lighting to underside near wheels and stabilizing jacks for night time setup
23. Add backup cameras to Excursion and to the camper
24. Add expansion tank to water system
25. Add quick disconnect to propane system for our Wave 3 propane heater
26. Add light switches inside the door and lights to steps
27. Add extended grab handle to steps/door
28. Replace stove hood vent fan with quiet and efficient fan
29. Possibly add fan to main bedroom vent
30. Add vent hoods (like MaxAir or similar) for powerless ventilation
31. Flush, test, and sanitize water and waste systems.
32. Pull all wheel hubs to inspect and pack bearings and inspect brakes
33. Shampoo all carpeting and wipe down entire camper walls, ceiling, cabinets, etc
34. Figure out where to pack everything we take with us
35. Do service and maintenance on our hybrid to get it ready to sale.
...and probably lots more, LOL
So you can see that batteries and power are very important, but lots of other moving pieces as well. If I miss a few things or make some mistakes, please point them out, but don't get too frustrated with me- lots of things happening and being planned :W
I guess this is all part of coming from a camper we spent years modding and setting up just the way we wanted and then starting over with another camper. Exciting for sure! (but also a lot of work)
Keep the tips and info coming. They are HUGE helps :)
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
