SoundGuy
Apr 20, 2017Explorer
To the OP ...
FYI here's an East Penn VRLA Tech Manual you might want to read through if you're at all interested in EP non-flooded batteries. It's pretty clear that temperature corrected charging (which your new PD9270 does not offer) is a requirement as far as East Penn is concerned. Personally, I'd be looking for similar documentation that relates to any other make / model of battery you may be interested in before making any battery purchase. For example, AFAIK Trojan calls for a bulk charge rate of 14.8 volts which your new PD doesn't do, in which case you would have wanted to buy the 14.8 volt version.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
