jrnymn7's avatar
jrnymn7
Derating 24v Solar Panels?
I'm considering running two 250w/24v poly panels; tracked/pointed during spring/fall, and flat during the summer; thru the Tracer 3215BN 30a mppt controller. I can also get 200w/24v mono panels, locally, but would much prefer poly, seeing as I need the panels to perform well in low light conditions, as is common during early spring/late fall.
I have noticed when running two 140w/12v panels, tracked/pointed, thru the 30a Tracer, it is not uncommon to see 300w in and out,
this time of year. That's an increase of 7% over their rating. So, 500w (2x 250w) + 7% = 535w.
But I've also seen a 25% drop in power, at noon, going flat vs. tracked. So, 535w - 25% = 401w flat.
On a 60% soc bank, charging voltage would begin in the low 13's range, say 13.2v. 401w / 13.2v = ~ 30a... the controllers max current rating. But I would prefer not to max out the controller, especially in hot summer conditions, so I would prefer to lower wattage, and thus max/peak output amps, during the summer months.
Again, it's only during the peak summer period, say a month or so either side of the solstice, that concerns me. The rest of the year maxing out the controller will likely not be a problem, even when pointed.
So I'm wondering if de-rating the panels would be the solution, and how I should go about doing so? Would it depend on series vs. parallel wiring, for example? Or would it depend on the number of diodes and/or cells, for instance?
Your input is much appreciated!
Having RV issues? Connect with others who have been in your shoes.24,292 PostsLatest Activity: Jul 31, 2025
