pianotuna
Nov 04, 2022Nomad III
Hi Almot,
Any of the modern MPPT's with a high voltage input.
The devil is in the details.
My controller is advertised as 30 amp. But.....if you double the voltage that drops to about 24 amps.
So I'm in the situation if I want to add more or replace the panels--I have to replace the charge controller. If I went that route I'd pick an 60 amp unit.
I like Tristar because they "piggy back" three modules. That keeps the over head low when doing low light conditions:
https://www.morningstarcorp.com/products/tristar-mppt/
As soon amps increase over 20, the 2nd module starts up, if we can trust what the maker says.
Since I'm no longer full time it is unlikely that I'll do that. The system was designed with a large battery bank and UniSolar panels which react to three frequencies of light--but also have diodes between EVERY cell.
I did get as far as finding a modern German panel that had diodes between all cells--but they did not respond to my attempts to contact them.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
